I have a 97 protege and I am going to be putting in a new system. I thought I would get the guru's (and anyone else's) opinion on what type of enclosure I should use. I am deciding between ported or sealed. I have two 12" Rockford Fosgate Hx2 subs(RFD2212) that will be pushed with a 81000D MTX amp. the subs are 500 RMS each and the amp is supposed to be about 600W RMS(its been moded so it can push up to 1800W at peak). This is a mono amp, so the subs will be bridges together. Thanks ahead of time.
