sub and amp hookup question
oakley990099
08.5 CWP Mazdaspeed 3
I am sorta new to this and i was just wondering what i would wires i would need to just get this basic system hooked up to me 03 mazda6 s.. and the cost about... i had this previously hooked up to my pathfinder but i sold it and wanted to keep the system so the owner just cut the wires and gave it to me like that..
-thnks
from left to right i see (power, Remote turn on, power) for the first block. then it will be the speaker left and right terminals. This is of course for the fused side of the amp. then you will also some RCA's to get the signal from the head unit to the amp. Now if your factory deck does not have a sub out then you will need a Line Output Converter. Since its a jensen and thats prolly 650Peak watts i would say you would be more then fine with 8awg wiring for the power side. 16awg wire would be fine for the speakers, still overkill but it would be fine, 18awg would most likely be ok.
A simple wiring kit can be pickked up at walmart for under 40 bucks. Same with the LOC.
