First Car...P5 said:
I'm planning on getting a system for my car soon and after wandering around the net for the past couple days, I finally came across a setup which I like. The thing is, this is my first system and I'm not 100% positive as to what I'm doing.
These two sentances go all to well together.
You should NEVER shop or do audio research on the NET, maybe once you know what you want but otherwise not.
Its audio, you have to hear it! All the text in the world can not accuratley describe how somehting will sound to you. Go listen to some subs and amps. Go to a show and see what people are running. Talk to them about it. Stop into a few stores and listen to what they have. Your eyes are a totaly useless organ when it comes to audio. Go with what your ears tell you.
Running 2 subs with a bajesus of power does alot of things that no one tends to point out on the net.
1st, I hope you didn't like listening to music, becuase if you are running that sub setup and factory speakers or even just non-amplified speakers, then you will not be hearing much actual music any longer. You should be matching the subs to the rest of the system and your eventaul goals. Remeber, the only people subwoofers impress, are the people that want to steal them.
2nd, Your car is going to rattle like crazy. People think dyaomat or a sound deadener will stop this. It won't and it can't. Everything from the tail lights to the dash panels will rattle.
Infinitly makes a decnet product, but its not for everyone. Nothing in audio is. Hifonics seem to be holding together well these days but I find there power ratings highly exagerated. They are not as they once were and now they are whored on the net....never a good trend.
THe product you linked to will work together and work rather well, they are a good match. However, being a class AB amplifier, the amp will draw a TON of power from the car. Expect alot of head light dimming. Also, the wiring for the amp will not be cheap. Anything smaller then 4 guage power/ground is unacceptable.
If you can, buy the single voice coil versions of those subs and a mono subwoofer amplifier. It should put out the same or more power while drawing less current from the car.
