stupid tire question
mctoone
Contributor
The guys at work today were looking at my new P5 and were impressed with the "low profile" tires it had. They said that when they need to be replaced I had to replace them with the same type of tire. Low profile...I know nothing about tires. Is this true? And are low profile tires more expensive and give a less comfortable ride than normal tires? Would I need to change the rims to get normal tires on there? I didn't even notice what kind of tires were on the car. Low profile? God I'm naive when it comes to these things.
you're fine. low profile means that the ratio of your sidewall compared to the width of the tire is small. low profile tires means that they don't look like donuts.
So they are low profiles on the car? It's not that I don't like them, but I don't want to be replacing tires and especially if they are more expensive than normal ones. Grip might be important but I don't drive that fast so comfort would be better for me! I'm not one of those old farts out there but I'm not a racer either! I use my car all day long for work so I don't want to be going through tires regularly. Can normal donut tires be put on the rims once these Dunlops wear out?
the only real thing you have to be concerned about it the overall diameter of the wheel/tire combo because that has a direct effect on your speedometer and odometer readings. if you stick with the stock rims, you will have to stay with the same tire size, or go with a tire that is only slightly different in size (you can do a search to closely related sizes). if you get a smaller diameter wheel, you can get a tire with a larger sidewall (looks more like a donut) and still have roughly the same overall diamter. that would give you a more "cushy" ride, and you could get tires that were less expensive.
Relax... first of all those tires should last you at least 40-50K miles... second, "low profile" generally means that the middle number on the tire size is 50 or below... and third, you can basically get as cheap a tire as you want in maybe size 195/65-16... and it'll be fine...
