type5 said:I went to rotate my tires, but I cannot get the rear OE rims off. They are stuck to the hub. Kicking the tire around the edges did not budge them.
Anyone know any tricks to remove stuck on rims?
BigBlue said:And don't forget to use some handy WD-40 if you got some kicking around...that stuff loosens anything!
Red Baron said:
WD-40 is fantastic to loosen things, but don't count on it as a lubricant...because it ain't one : WD = Water Dispersant
Hope we helped ya! Good luck.
mp5 said:I use to experience the same problem until I discovered an easy way to loosen the rim. Before jacking the car, loosen the lug nuts a good way without totally removing them. As you jack up the car, the inward movment of the extending suspension will break free the rim. Then just back out the lug nuts the rest of the way and the rim should come right off. No gaurentees, but its always worked for me.
BigBlue said:
Nope I'd never use it as lubricant...just to loosen up bolts and stuff. Lol, all this time using it and I had no clue what the WD stood for...thanks for the info.![]()
