ok so one of the studs on the exhaust side of the head stripped the threads and its not repairable. should i go with a larger bolt or can a helicoil be used to repair it?
tried it but the tap doest grab since there is no metal to grab onto. i never used helicoils so i am not sure id you drill out and put the inserts or if you need some thread or what.
aluminum is very soft metal, you strip that s*** and you're ******
and when you reinstall the manifold, make sure you torque it to spec! I posted that s*** in the sticky and most people ignore it! overtorquing results in stripped threads on the MSP!
