I have a high pitched rattle or ping sound when I shift or let out the clutch. It makes this sound every time unless I'm real smooth or easy. It sort of sounds like an exhaust heat shield is loose.
In searching for it I found this cap that seems to be the pressure relief valve its where the shift levers come out of the transmission . It feels loose, but is supported internally by a spring. are they all like that? I think it may be the source of this noise or is it probably something else?
I think it is your finger!
Could be related to that MASSIVE intercooler LOL
If you had a cobb sri I would say check the mount to the battery tray.....
i have a similar issue, it sounds like the exhaust is banging or jiggiling. I gotta check my rear mount and then exhaust hangers. Not sure what it could be.
What made you lead to this thought? Im gonna jack my car up tonihgt or this weeeknd to at least double check on the mount. Im sur eits ine but worht a check.
I had something similar as one of the symptoms of my left front's wheel not being screwed on to "factory recommended settings" as my dealer put it.
I rotated the wheels its not that. did the it work for you?
