Stock MSP ECU Map
nicholsspeed
03.5 MSP
I am looking for the Stock Hex file from the MSP ecu. i know i have read somewhere on here that someone had it, but i can not find the thread.
I have a Tuner at Force Fed in Wilmington NC that is going to look into Cracking the ECU.
if you have it, or know someone who dose, please Send me a PM.
do you think its worth it? id be game to give it a try if it helps eliminate horrible tuning and pig rich fuel map we have instead of dropping $1500 for a haltech
there is also a guy in jamaica running a 1.8bp mazda motor on I believe an OBD-0 or OBD-1 honda ECU with hondata add on etc for larger injectors and tuning everything.
the thing is why waste all this time trying to decode and program the stock ecy and hack the s*** out of your car when you can just buy a used afc for $200 or less?
who actually needs anything more than the ability to control larger injectors when you are on a stock block anyways.
and if you have the $ invested in a built motor, would you want anything less than a stand alone ems running your pride and joy?
