Stock MS3 2008 wheels with 225/40 R18
Santo
Ok I blew out one of my tires, the replacement 215/45 is hard to find down here, and I was thinkin on replacing my tires with 225/40 R18 keeping the stock wheels.
Any experiences with this setup?
Any advice? I might also consider 235/40 R18 is it safe with the stock 7.5" wheel?
Thanks in advance.
The 2008 wheels are 7" wide. 225/40 would be an acceptable substitute, as would 225/45.
235/40 would be pretty darn wide for a 7" wheel, but I'm sure you could get it to mount up.
I thought 2008 wheels were 7.5" I will measure them today ????
if that's the case is it ok to use 235/40 R18 ??
Thanks!
If you've already bought 235s, I wouldn't panic, it's probably fine. 225s would be better though.
You were right I physically measured my wheels and the stock wheels fot 2008 are 7"
Given that, I went with the 225 / 40 R18 Nexen's (N1000) we will see how they perform...
The 225 / 40 R 18 look great but according to the manufacturer the minimum rim width should be 8" The tires handle really well on cornering or braking, but awful on zigzag I can upset the car relly easy doing zig zag, Do you think this is beacause of the 7" rims or is this a problem with the tires?
I don't feel the precision on steering that my MS3 used to have with the 215/45 R18 ...
any thoughts?
