Stock DP Removal
How Would You Rate The DP Removal?
  • No problems
    Votes: 1 11.1%
  • O2 removal took time, but DP came out fine
    Votes: 1 11.1%
  • Broke O2, DP came out fine
    Votes: 0 0.0%
  • O2 was easy, but DP removal sucked
    Votes: 2 22.2%
  • Broke a stud or two, but DP came out easy
    Votes: 0 0.0%
  • Broke a stud or two, O2 was tough, DP came out easy
    Votes: 1 11.1%
  • Broke a stud or two, O2 was tough, DP was a b****
    Votes: 1 11.1%
  • Broke a stud or two, broke an O2, DP came out easy
    Votes: 0 0.0%
  • Broke a stud or two, broke an O2, DP was a b****
    Votes: 0 0.0%
  • Worse than any option
    Votes: 3 33.3%
  • Total voters
    9
Speedy3
Contributor
2007 Cosmic Blue MS3
For people planning to do DP mods (like myself), I think this survey will help prepare people for the work ahead.....
I mean't this poll to apply to people who did a stock DP removal from a Mazdaspeed 3 that hasn't had any exhaust work done previously.
Does anyone know if the WB O2 won't come out, does that heat shield around it need to be cut off? Has anyone had this happen?
The guy who did mine got all the bolts out easy the o2 sensor was a b**** a thread was messed up but it works just fine.
O2 was easy if you follow corksports instructions (at least it was for me). Had that one goddamn bolt holding me up for awhile, but other than that it was just a lot of tedious work. Definitely need a good variety of tools or else you'll get stuck or hung up somewhere. Takes a lot of time and patience. My hands hurt
