Well I have been battling this for over a year now. Intermittently, my car will not start. It just clicks under the dash and under the hood. It will take several times of turning the key back n forth to start. I replaced the starter with a new one last fall but that did not fix. I've replaced the battery with no dice. I checked the resistance in the wires going to the starter and they were well within limits. Theres no corrosion as battery is brand new and battery cables and terminals are fairly new as well. Ground cables are good too. What can I check next or what parts can I start replacing that could contribute to this problem?
