axisboldaslove
- 07 MS3 GT Heavily Modified
thanks alot i will look at these...so are you still having trouble connecting to your ss afc though...like can u upload a map?
oh i will love you forever!!!! trust me...but you are still having troubles with getting the r4 software to connect to the ss afc right?
u must check what com port the USB/serial cable is on. You do this by right clicking my computer>properties>device manager
By default it probably won't be set at any com port between 1-4
You have to manually set it. Let me try and get some screen shots
if the AFC was not powering up, the car would not run. the AFC acts as a powered intercept for all the sensors and the computer. if the unit did not have power, it would act as a dead box basically and the car would not run at all. if the unit were faulty in any way, it would more than likely still not allow the car to run. i would bet the map on it is just tailored to the prior owner.
*you ninj'd meit'll be under usb serial bus controllers and then look for usb to serial com
I think i have an issue with the afc not sending the right signals when it's not supposed to be interefering with the signals. (values set to 10)
also it doesn't send ecu into open loop when it's supposed to. sigh.. perhaps time for a new one.
*you ninj'd me
^not quite... but yes if it is indeed installed you will see it there but to configure it you must go to
right click my computer>properties>hard ware>device manager
click on Ports
right click USB Serial Port (COMx)>Properties where the x is what current com port its on
then in the properties window click Port Settings>Advanced
Than you can choose the com port you want it on
hope this solves your problem... and yes like ken said the ignition has to be on also
now i'll be getting back to updating OSX
