shane02pro5
25ish_psi
- New Caney TX
500hp at the crank not to the wheels so closer to 440ish whp in a several hundred pound heavier car!
Yes it's without saying that you can obviously get more power from many many other platforms.
Then again I had a goal of as close to 400whp as I could which will eat up just about anything on the road including my bosses $80k 08 Z06 (from a roll any speed!) And possibly at the track with slicks should net me a very low 12 or lower.
I love the looks, styling and room I have for my two boys and their crap with my little P5 over most everything out there new or old.... just needed to catch up on every other aspect of it!!
Point is do you really want to cruise around on some gay ass scooter no matter how fast it is!?
Id have to see the gallardo part to believe it till you post a vid I'm callin bs. If it did infact pull on a gallardo it would totaly change my opinio on the fast part
the MP3 is an economy car from 2001... it was never meant to go fast, nor were any proteges for that matter. the MSP was the first mazdaspeed so there were obviously **** ups (weak rods and tranny) if you really want to mod the damn thing throw a built engine into it and GTX revised gears and your pretty much set to 400hp at the crank with barely any worries if you treat her right.Holy s*** ok you changed my mindI will no longer rag on how slow they are built...which obviously they're not. But I still wouldn't swap an srt4 motor into it or a honda motor. I still wana see somebody swap a 4g63 I wish I had the money to do it or go turbo actually may make me wana keep my mp3
Thought the evo and talon had the same motor just different head and turbo? A 4g63 is the same either way you go the talon my brother had the motor was on the passenger side just like the protege...
And sorry but your wrong on the sr20 part they can easily push 600whp but the fwd trans can't hold up to the power.nissan used the same motor as the sylvia. I know this cause I've done s*** tons of research between the sr20 and rb series. On a side note the sr20 can hold around 400 hp on stock internals
And I also plan to do some autox this summer if I can get everything fixed.
