Sportronic Shift?
Well, kinda, maybe, mostly it won't go to the next gear if you try to shift again too soon. It's like you have to have it in gear for a minimum amount of time before it'll let you go to the next one. Most of the time this is all right but if you're trying to bust a move through the lower gears then you want to shift sooner it can't keep up & you end up winding out 2nd because it didn't shift when you told it too then you have to let the rpms come down before it will actually shift again. ANNOYING!!!!
i got used to it so now its all pretty smooth. you do have to shift a little earlier because of the slight delay, not a second or so maybe a quarter or less but noticeable.
The bad thing is (& I'm talking about where you need to sport it up a bit) if you don't do it just perfect you get trapped in a gear you don't need. Passive driving is not a problem. In auto mode I don't like how it'll jump down too far for a passing gear depending on how far you push the gas pedal. Yes I have an auto & I will bust on it's shortcomings but if I drove the manual the way I get to drive in my truck I'd be blowin up synchronizers, loosing gears or whatever like others do so I'll just save all that for in the truck.
ive got an auto too, but ill run it through the gears (probably not very good on the tranny but it is fun). i also get annoyed with the way the auto shifts when you press on the gas, itll kick from 4th to 2nd and the whole car will jerk...not cool...but yea when im bored ill turn off the o/d and throw it into 1 and run up into drive (switchin off o/d to hit 4th gear)
anyone else do that?
although the sportronic is awesome for controling the auto, ive noticed that it takes up so much more gas!...i kno most of you are about to say duh, but even leaving it in 4th gear seems to consume more gas than when its off...but besides that, its a nice way to overcome the weakness of the full auto mode...btw, if u guys think chinatown has some good dim sum, check out sam woo out in rowland heights...awesome stuff!
haha...there was also king's dim sum in monterey park...but they closed down a while back...
I also have a Sport AT P5 and got a question for you all. When I'm driving along I sometimes put it on manual mode and the 4th gear iluminates then I shift it down to second gear and floor it. The car pulls hard a little and I up shift to 3rd and 4th.
Doing this am I damaging my auto tranny or anything at all? Thanks In advance.
They say it will but I don't see how it is any different then the way the full auto downshifts hard and in manual mode shifts are smoother.
That was the place slkt (Sheldon) was trying to tell me about. That sux it closed down. I just go to China town cuz its only 30 mins from me. And I can never get enough of it.
Remember...some of these clowns have an 02 where there was no sport shifter.
they have no idea what the **** they are saying.
pathetic really.
You really didn't have a question but more of a statement.
But...for the other postings...
taking it out of auto to manual (4th) will take more gas. In full auto it goes to OD when cruising around. Putting it into 4th manually takes it out of OD permanently.
IMO...you have to know how to drive an auto about as much as a stick. There are shift points that the auto will make according to your driving. I can go from OD to 2nd at will just by pressing the throttle a certian amount. I can also hold the gas under acceleration to get it to shift where I want. Wether it be at 3k rpms or 6k rpms. You have to know the cars shift points.
IMO...it feels more responsive because it doesn't go from OD to 2nd or what ever. YOU have it int he gear you want and there is no lag in shifting and with the rpm's building up. Also, the shift "lag" is exactly 500 rpms. Shift it manually at 6500 and it will shift at 7k (first gear). Shift it at 6k and it will transition at 6500, aka redline. BTW, if there is an OD switch on the sport shift P5 I haven't found it yet.
OH, and don't listen to the knucklehead blaming poor driving skills on the auto.
as far as "rediculous low shift points"...I have no idea what you are talking about. I keep mine floored and I can watch it shift at 6500.
and this..."I just don't like how it still makes you shift when it wants to be shifted to a certain degree."...it will not do a 1-2-3 in a split second. there is a couple second delay. going from 2-1-2 will yield the same result. Racing through city traffic prolly isn't the way to drive any how.
"It's definitely better than auto mode but still not nearly as good as manual where it's in the gear you put it in when you put it there & you can count on it being there where you are more one with the vehicle. "...Funny really. The auto never upshifts for you and you will hit fuel cut off. It will downshift to 1st when you hit 3mph. WHy you need 2nd, 3rd, 4th, 8th at 3mph is beyond me.
reliability? either manually or a regular auto without "sport shift", the gears are selected electronically anyways. The only downsides I can see are...one takes the car past redline one too many times or dropping to a lower gear without rev matching, which will immediately induce engine braking.
As I have said...you have to know how to drive an auto. It's a fine technology that serves its purpose.
I was talking about "normal" driving around town. Not flooring it. Of course we may have different ideas of normal, but, whatever.
Nice contradiction, "I keep mine floored..." but "Racing through city traffic...." Guess you meant 6500 on the track? I don't redline my car. Yet another fresh squeezed heap of steaming wisdom about driving habits. Until you pay my car note, gas, registration, insurance, maintenance or tickets, shove it. Do you really expect people to listen to you telling them how they should drive their own cars? Seriously, have some kids, they'll have to listen. I'm gonna drive as situations dictate in any given moment just as you "prolly" do & I couldn't give less of a s*** who likes it or not. I don't like having to deal with unlimited assholes every time you go somewhere regardless of how you drive. Until I can there will be moments of variance in my normally subdued just minding my own business less than supersonic driving habits. Nobody needs 4th gear at 3mph & everybody knows that captain brilliance. That wasn't even what was being said-refer to your "downsides comment", you're restating what was being implied. You missed the comparison about sportronic manual mode vs. an actual manual trans with a clutch making you more connected with what the car needs & expects shiftwise. Thanks though for all the common sense about the need to adapt to different engine/trans setups to make the most of them-somebody out there might not have actually known that. I will agree with the part about automatic trans being a fine technology that serves its purpose.
you sound like a pathetic whiney b**** on pms. Do us a favor and put the tampon in your pussy and not your mouth.
fyi numbnuts... "I keep mine floored..." but "Racing through city traffic...." get a ******* clue. Streets do get empty from time to time. You on the interstate at 6 am by any chance?
Looks like you had nothing to input but bitching. stfu pube.
You're the ******* pussy so stuff yourself b****. Got plenty of clues dipshit. Sure, on freeways 5 am daily. You got the lock on nothing to input wadlover so you stfu & go suck yourself pretzel boy.
Dude can flame all he wants, I don't give a s***. He's just a smack talkin chocolate starfish collector. Have at it.
GOD DAMN! Can't even have a ******* civilized conversation on here. Eh, oh well.
