Sport20Sedan/Jeremy T
LinuxRacr
Contributor
2001 Mazda MP3
Guys,
If you have the time could you list every component you had to swap out from your old engine to you FS-ZE? This will help me to know what to expect. I know I've asked Sport20 before over the phone, but a lot has happened since then. Thanks for your help.
Jeremy D and myself both had the work done at a shop. The only thing I can tell you is that it is a direct swap. Thus, everything mounts and lines up properly. We each had one problem, which turned out to be a crank angle sensor.
