Or just disconnect the positive then go instead and play some Gears of War or FORZA 2
come back out after about 10 minutes and hook it back up.... don't forget to reset your clock and do the window trick
(hold go to each door and hold the button down until the window goes all the way down, then hold the button up til the window goes all the way up and you feel/hear a click about a second after then let go.... has to be done at each door)
That should help reset your ECU and "learn" your mods.....
