speed 3 tranny in 3s hatch?
stillcantswim
Mazda 3s
I am simply looking to cruise on highway at a lower rpm. Just wondering if it's possible and how much modification if any would be needed.
I have no idea if it is a straightforward swap, in part because I don't know how differently the engines mount to the transmissions.
I assume that this 3s has the five-speed manual transmission. Model variants are different in the U.S. and Canada, and there is no year given, so it's not clear.
Is the gearing actually higher in the 6-speed Mazdaspeed3 transmission than the stock transmission? The extra gear often just means smaller steps between gears, rather than an additional taller top gear.
Speed3 trans is quite different and would involve swapping alot more then just the trans.
You can use a later model mazda3 6 speed trans though. Those are pretty much a direct swap. But you will need the 6 speed cables, and shifter assembly also. Everything else is a direct swap.
I assume that this means using the Skyactiv-MT 6-speed found in 2012 and up Mazda3 with the Skyactiv-G 2.0 engine (such as my 2012 GS-Sky), and in all 2014-2015 manual transmission Mazda3 variants. It's interesting that this is a direct swap, since the engine is different (no longer the MZR) - they must have used the MZR's bellhousing pattern on the new engine. Reduced size and weight were prime targets of the Skyactiv-MT design, so I guess I'm not surprised that this 6-speed fits in the space vacated by the previous 5-speed.
Does anyone have sources of gear ratios - both transmission and final drive - for both stillcantswim's 5-speed and the Skyactiv-MT 6-speed?
It was more specific to the older 3's. Donor trans would be the 2010+ 3S 6 speed.
Ah, that makes sense. I had not heard of that transmission in Canada - the second generation (model years 2009-2013) Mazdaspeed3 came with a 6-speed, but I thought that the other levels (GX, GS, GT) came only with a 5-speed, until the SkyActiv version. Maybe the 6-speed came with the 2.5L engine in the GT, which might correspond to the "s" version elsewhere.
