spectre MAF housing
06 LS MS6
07 BM GT (shell has been struck from the roll)
has anyone used this? if so which insert did you find to be best
the P/N is 9405
People have used it and found that the diameter of the MAF housing doesn't match the stock diameter and causing a code. If you search around, you should be able to find the thread.
i tried it and yes it throws the cel. but... i could not believe the amount of pull if had even comparing to the mazdaspeed or a modified stock maf housing. modified, meaning that i cut the maf off the box and attached a cpe filter to it.
