SOS My AC is dead...
prboy3
Mazda3 Black Mica Auto
Hey forum,
Just drop my girlfriend at work and had the AC running. Suddenly I heard a little "clunk" sound comming from the air vents. I had my iPod playing with the iTrip. The reason I mention this is because when the AC was on there was a bad interference with the iTrip (this hasn't happen to my setup before). When I turned OFF the AC the interference was gone and so was the AC. It never turned on again. When I turn on the AC control it seams as if the Thermostat or the Compresor turns on, but the problem is no air comming from the vents (as if the fan doesn't turn on). I'm afraid the dealer would void this from warranty cuz I installed an sub-woofer last year (conections behind the radio). Also I routed the Radar Detector cable through the back of the console.
Anyway I'm taking it to the dealer this monday to get things check like: AC PROBLEM, SUSPENTION CLUNK, AIRBAG RECALL and OIL CHANGE...
Any input will be appreciated...any of you have had this problem(s)?
Thanks in advance...
PRBOY3
