7
70
Ok, I was board at work, and I decided to figure out if the MP3 actually sits lower than the regular Protege. Before you read the rest, I bet most of you will say yes.
But, here is some interesting info:
The wheel diameters for each tire size is as follows:
195/55R15 is 23.45"
195/50R16 is 23.68"
205/45R17 is 24.26"
Now, the Protege MP3 is lowered 5 mm or .2". According to the Mazda web-site, the overall height of the MP3 is also .2". shoter than the stock Protege.
But, if the wheel diameter is .81" more on our tires over the 15" tires, doesn't that cancel out the .2" drop??
There is a .58" difference between the 17" and 16", once again, doesn't that cancel out the .2" drop??
Wheel diameter effects both the accuracy of the speedo, and the ride height of the car.
The MP3s overall height isn't really any shorter than the stock Protege, and if anything is just slightly taller. Pretty funny.
195/55R15 is 23.45"
195/50R16 is 23.68"
205/45R17 is 24.26"
