hornsfan10609
Certified Mazda Tech
- 2003.5 Mazdaspeed Protege x2
You should put new fittings on the ends of that vacuum block and move it to the brake booster line, then you can run individual lines to each source.
At higher boost, the Turbo XS will bleed out.
The Tial 50mm is solid, but it is meant for 20+ PSI
