The nice thing about boards like this is that you can learn from others mistakes. I have built my turbo kit from scratch. I chose a Garrett T-25 with a slightly diferent pitch than what comes stock on a MSP. It's a fantastic unit. It just doesn't have the HYPE that the others like the Hybrid have. Don't be afraid to rely on the little T-25. With proper research and smart modifications like a more efficient intercooler and fuel management, that little guy should be able to give you 10 PSI daily. Just remember that your car is running 9.9:1 compression. When you apply a charge of 14.5 PSI or 1 BAR of pressure, your compression ratio would doubles because you have put twice the air in the same cylinder. That will more than likely cause detonation unless everything else is in top knotch shape.
You can probably see the T-25 on My Sig.
