Siruis offer
i just called about my order said ther were in stock and would send out in 3 days
Yep... I got a call yesterday as well from them. They're on the way.
What are the options for the atenna? I am not sure if I want a magnet one on my roof. Is there anyway to mount it in the car... or in the trunk?
rocketspeed said:
I got a call from these guys today (I had pretty much written them off) telling me that units were now in and asking if I still wanted one. They said its not the unit that the first folks got, its something different as that is no longer made.
See and everyone wanted to bag out.....good thing you guys didn't
The magnet mount is nice. Easy to install. The directions say you can install it on the trunk or the roof. Problem with the trunk is the thing almost sits under our wing which is a bad idea. It needs to "see the sky" ALSO it says to be sure it's away 12 inches from any edge. That's what the little black plastic thing is for. ALSO inside the car is bad cause then the signal has to go through the car. Read the directions with the antenna you get. They said in the end best proformance is using the roof.
The only bad part about the magnet-mount is that if a grain of sand gets between it and the roof, it'll scratch up your paint. Mix that with moisture, and you've got a pin-head sized rust spot that will continue to grow.
yea you have to clean the surface before mounting it, but no sand is going to get under it while it's mounted. It's a pretty god magnet.
I put mine inside the back window and I rarely have a problem with reception. Window's are tinted as well. I didn't like the look of it on the outside.
