I am about to install a factory Sirius setup in my MS3. I was thinking of the possibility of putting the antenna inside the rear spoiler which is made of plastic instead of sticking it to the roof. I think it should be possible to put it inside through the 3rd brake light hole and snake the cable down the rubber tubes to the main body and from there down to the right wheel well for attachment to the receiver.
Questions:
1) Anyone tried this? If so, did it work?
2) Is the metallic paint going to reduce the signal level to the antenna?
3) Is the plastic of the spoiler going to reduce the signal level?
4) How much of the interior am I going to have to remove to get the wire from the top of the hatch down to the wheel well?
5) Am I out of my mind?
Questions:
