This is very true. Just cut the ground (-) at the light and run it to the (+). No need to do anything other than that.MJG said:did you have to undo the fender skirt to run the wires... and also I found out that all you really have to do is take your ground from your sidemarker and tap it into the trigger wire which is the light green with black stripe. It will show ground untill you hit your turn signal and thats what makes it go in and out .
t3ase said:This is very true. Just cut the ground (-) at the light and run it to the (+). No need to do anything other than that.
