Side mirror replacement. Can I upgrade?
jweaks
Contributor
Mazda CX-9 Sport 2012 & Mazda3 2018 Touring
My 2012 CX-9 got a side mirror busted. It's the Sport trim with not extras, so not blind spot detection or blinker in the mirror.
Is there an aftermarket side mirror that has a blind spot indicator built in? I'm guessing it'd be a little light, without any sound.
Or can I at least buy the version with turn signal and it will work with the current wiring?
The blind spot monitor will definitely not work - the sensors for that system are behind the rear bumpers.
The turn signal light will most likely not work - the wiring harnesses are different between the trim levels.
New Threads
