Show me your CX-5 wheels
You got a cool ride there Chris. Been checking out your turbo build it and looks pretty cool!
Some where, some time, at the other side of the globe...
Weighing at just 22.5lbs (or 10.2kg)...
They came together...
Lookin good X5actor! I really like the color of those wheels.
Thank you. It took me quite a while to find a set of wheels to my liking. I wanted dark colored wheels to match but not too black. There were many considerations I had - it was either nice design and lack of color choice; or wheels that had the color I like but I didn't like the design. Then came the weight of the upsized wheels that I am also particular about. So cut the long story short, this is by far the better choice to what I like and can accept.
So far, after some weeks, it drives well:)
Hey all! New member here, just picked up our 2016 GS (or Touring as it seems to be known everywhere else) yesterday. Dealership happened to have a set of the Mazda6 GT 19's lying around and wasn't about to pass those up!
I don't know if this has been posted, but while looking for something else related to CX-5 on youtube this video popped up as recommended.
It shows a pretty wide range of wheels on different color CX-5.
Even if they don't sell that brand locally, it might give you an idea of a new look for your ride you hadn't considered before:
https://www.youtube.com/watch?v=LcYn_dYtfOc
What did you do for tires?
Here are my wheels. RTX Envy 20x8.5 et38.
I have 255-40-20 tires on now but they have to be replaced soon. I'll be looking to get 245-45-20 instead.
Is that stock ride height? What is the difference in overall diameter vs stock for your current setup with the 40s or the new setup with the 45s? I assume you are going up because of the harsh ride?
the 255-40s are not stock height to my OEM 17s. They are about 2-3% off. It's just that I bought the wheel and tire set used and that is what was on there. By using the online tire calculators, I see that 245-45-20 is the closest to 225-65-17. And since the used tires are almost finished, I'll be getting the proper size. As for the ride, I don't find it too bad. If they were the proper size, I would still be okay with getting that size again.
1" spacers
no, i used original front struts and original rear shocks. if you prefer to extend... you will actually need a different route up front ( 1" thick custom made strut spacer that sandwich between strut top and strut tower, then only a 1 inch spring spacer), and adjustable camber bolts. the reason is because if you allow it to extend further 1 inch the wheels begin to drastically positive camber.
the rear you can create a 1/2" taller shock spacer to allow for extra extension since the studs coming from the body are extra long.
how i know this is because i lifted my mazda3 hatchback 1.5" taller for rally racing in the back roads of mojave national preserve deserts. the mazda3 and cx-5 share nearly identical suspension with minor differences up front as to how the strut is held to the knuckle.
Do you have a contact or reference link for these? I am interested in doing this for just a little more clearance for my tires. Thanks!
-Rich
