Should I get front camber kit?
lyndonvang
Mazdaspeed Protege #386
Ok I bought new tires last summer and now the inside part is all worn out. I just got another set of front tires. The problem is that my front tires are wearing out too fast. I've taken it to pep boys abou 7 imes in 4 months(got the 3yr warranty) and they still can't fix it. The privious owner put some progress springs on. Would I need a camber kit to fix it or could it be bad struts? The front end of the car is a little lower the the back. The car still drifts to the right.
1. How many miles are on the car?
2. Are the struts the original ones that came from the factory?
'the front sits lower than the back' you have a slight rake due to your after market springs I guess. My .02 is depending on the milage or how hard the previous ower flogged the car is to replace all your struts for GP...
There original strutrs. With about 113k on them. Don't want to get new ones unless I have to, kinda low on $$. Would a camber kit help if the struts are out?
