Shop Tools
Matthew
Contributor
CX9, CX5, i8
a. DRILL PRESS: A tall upright machine useful for suddenly snatching
flat metal bar stock out of your hands so that it smacks you in the
chest and flings your beer across the room, splattering it against
that freshly painted part you were drying.
b. WIRE WHEEL: Cleans paint off bolts and then throws them somewhere
under the workbench with the speed of light. Also removes fingerprint
whorls and hard-earned guitar calluses in about the time it takes you
to say, "Ouch...."
c. ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes until you die of old age
d. PLIERS: Used to round off bolt heads.
e. HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
f. VISE-GRIPS: Used to round off bolt heads. If nothing else is
available, they can also be used to transfer intense welding heat to
the palm of your hand.
g. OXYACETYLENE TORCH: Used almost entirely for lighting various
flammable objects in your shop on fire. Also handy for igniting the
grease inside a wheel hub you're trying to get the bearing race out of.
h. WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or
1/2 socket you've been searching for the last 15 minutes.
i. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
after you have installed your new disk brake pads, trapping the jack
handle firmly under the bumper.
j. EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile
upward off a hydraulic jack handle.
k. TWEEZERS: A tool for removing wood splinters.
l. PHONE: Tool for calling your neighbor to see if he has another
hydraulic floor jack.
m. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for
spreading mayonnaise; used mainly for getting dog-do off your boot.
n. E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt
holes and is ten times harder than any known drill bit.
o. TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the
tensile strength of bolts and fuel lines you may have forgotten to
disconnect.
p.CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool
that inexplicably has an accurately machined screwdriver tip on the
end without the handle.
q.AVIATION METAL SNIPS: See hacksaw.
r. TROUBLE LIGHT: The home builder's own tanning booth. Sometimes
called drop light, it is a good source of vitamin D, "the sunshine
vitamin," which is not otherwise found under cars at night. Health
benefits aside, it's main purpose is to consume 40-watt light bulbs at
about the same rate that 105-mm howitzer shells might be used during,
say, the first few hours of the Battle of the Bulge. More often dark
than light, its name is somewhat misleading.
s.PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
paper-and-tin oil cans and splash oil on your shirt; can also be used,
as the name implies, to round off Phillips screw heads.
t.AIR COMPRESSOR: A machine that takes energy produced in a
coal-burning power plant 200 miles away and transforms it into
compressed air that travels by hose to a Chicago Pneumatic impact
wrench that grips rusty bolts last tightened 70 years ago by someone
at Ford, and rounds them off.
u.PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
v.HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
w.HAMMER: Originally employed as a weapon of war, the hammer nowadays
is used as a kind of divining rod to locate expensive parts not far
from the object we are trying to hit.
x.MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly
well on boxes containing seats, chrome and plastic parts.<!-- / message -->
Learned that one the hard way at work, killed 3 drill bits before i said f it... Funny stuff there...
to say, "Ouch...."
My shop teacher cheaped out on wire wheels once. I got done using one and found that I had a few hundred wires scuk in my torso.lol
Me too, what a pain in the ass!
thats great! this list is so true...and it shouldn't be. i spent some good money on those bolt-rounders!
lol, ditto
Try a carbide drill.
Well i work on a farm, and well carbide drill bit non-existant there, The skidloader it was on had to go into the shop to get a hydralic pump fixed anyway, so they just took care of it there. I was shocked as hell to even find ez-outs, i thought i would have to come home for one...
I'd say they are an accurate description of such shop tools.
I especially like:
easy out eat carbide alive
try cobalt or cryo'd bits... you'll be much better off.
I've "easy" outed a LOT of grade 8 bolts from a slab of steel that HAD to have them out, since it cost $80,000, and absolutely CAN NOT have broken bolts off in it. easyouts are hard mother f-ers though, for sure. I've broken no less than 10-12 off in those beams.
it sucks. better to try first with a reverse drill bit.
