I have a little more than a week with the front shocks on and it's definitely an improvement. Slightly stiffer than stock. The only issues i had were grinding down the brake line bracket where i couldnt get the dremel to fit and grind the inside but i was able to pry the bracket open slightly to fit the line and squeeze the pin that holds it in place.
The other issue was fitting the shock back to the wheel. You have shimmy a lot, then shimmy some more, and when you think you're done, down a beer and shimmy a whole lot more until its slightly in place and use a jack to lift the wheel up to where it needs to be, then shimmy some more (careful, the back bracket is supposed to squeeze between two plates) until it just slides into place like nothing then you wonder if you really had to go through that.
After the first try, i had a better understanding and thought the 2nd should be easier. Well it still took as much shimmying around to get that damn thing in place. All in all, 4 hrs for both which i had plenty of beer breaks in between.
The back shocks look easier and will be replacing them this weekend.
Best purchase ever!
