semi serious problem!!
flik815
so heres the problem.
if i boost my car or just accelerate quickly and then push in the clutch and hold it in(which there-for makes the rpms drop) the rpms drop past idle and the car dies. but i just let the clutch back out and it bump starts itself bc im already moving. it seems if the rpms drop to quick or suddenly then it dies like that. have no idea what the problem is. ive never seen this before.
man im telling you that i would almost bet that you have a vac leak. i had my car doing this to me for ever and i just started looking and i had a vac leak. a good way to find it is to get some carb and choke cleaner and spray it on the lines and if the car bogs down and almost dies that is area where the leak is coming from. the stock lines are crap and turn hard and crack.
sounds like a vac leak to me.... check your vac lines, also try checking your wastegate actuator. I think i've developed a small leak, so i'm going to be tracking down mine this weekend. Good luck!
