Seeking cylinder head bolt torque specs and engine manual
Hello I have Mazda Demio year around 2010-2015, not really sure as the seat belt label was not visible anymore. Its a Japan manufactured right hand drive vehicle.
I am working on changing the cylinder head gasket. Could you help me with the cylinder head bolts torque specs for it pls? What is the right amount should I torque them?...also if you can give me directions on where to find the engine manual for this type of vehicle. Thanks.
2010_05 MAZDA MZR 1.5 Manual
Form No 1993-1U-10E, Part No. 9999-95-MZR-11
Pg 01-10-27
Cylinder Bolt Inspection - Measure the length of each bolt.
If it exceeds the Maximum Specification, replace the bolt.
Cylinder Head Bolt Length:
- Standard: 128.9 - 129.5 mm
- Maximum: 130.2mm
Pg01-10-45
Cylinder Head Assembly
Bolt Tightening Torque: 18-22N.m
Rob
