Seals Leaking on 2008 Mazda CX-9
Brilliant
Mazda CX-9 Touring 2008
I have been told the seals on the rear axle are leaking and need repair. Thought I had a 2-year warranty and it was covered, now dealer says 2 years or 24K, which I missed by 4K if true. Wonder how much it cost to repair. As far as I know they are small leaks, but leaks. I am in Omaha. It is the touring model if that matters. Thanks.
Leaks means seeing fluid on the floor if not then it just seeping fluids. You should have checked the car when it was on the lift and you be the judge and see if its really seeping or leaking bad.
I had mine replaced before powertrain coverage expired (wet spots discovered), and post a thread notifying all on this forum to check for it.
