scmp3's build thread:start to...it will never be finished
I think my temp switch may have went bad and my fans never kicked on. The fans definitely didn't come on. But worked when hard wires to the battery no problem. And the relay is fine.
compression results.......
cyl 1
cyl 2
cyl 3
cyl 4
Nice! doing work I see...you doing all this in your "driveway"? that might be kind of difficult using the cherry picker on gravel. no?
got that covered. will take pics. need the cherry picker(beams dad has one), torque wrench, 32mm, and a ball joint fork. last 2 for getting the axles
Have an exedy stage 1 clutch coming and front/rear/side inserts 88 duromoter(Sp?) Awr motor mounts
new parts.....
new water pump and gasket. just has a little surface rust on it
exedy stange 1 clutch
88 duro awr front and rear motor mount and inserts. and new vibrant 3 inch 2 bolt flange to weld to my dump pipe to mate my 3inch dp too
just waiting on the hoist to come sometime soon. the motor is just held in right now by the pass side and trans mount. need to buy new fluids(trans, oil, and coolant.) also want to change the front and rear main seal, vc gasket, and re rtv the oil pan
some pics from the swap. no particular order.
new motor.
old rear motor mount.
my engine and tranny out
the best bolt on ever ;)
new clutch on
new awr 88 duro rear motor mount
new motor in
ill have to get some new pics of the car now that im driving it again
should be able to get some pics tonight.
What % tint? You got that thing back on the road fast! I have never seen a mount that destroyed. (i've done a full set of solid mounts on two different titanium MSPs).
its 33% over stock tint. and yes i got it on the road as fast as i could. and the mount had 228k miles on it.....
