sale pipes
You will be able to control Air/Fuel ratios with it. You can upload air/fuel tables or 'maps' into the unit using a serial cable. Most people have best luck with a USB to serial adapter. There are some air/fuel tables online that you can download. The car will run much better.
There is an install thread around here somewhere, that shows you how to connect the 5 wires that are required. Its easy if you know how to solder.
am i look at a power boost here or just something that will help my car run better for mods later
no power boost, just more 'even power'. Your powerband will be smoother and nicer for everyday driving. It gets rid of hesitation problems that so many MSP owners have seen, and it allows for safe moddifications. If you get a wideband O2 gauge, you can tune it and watch your AFRs to see if you made the right changes.
ooooo ok
well thanks for the input
sooo im probly going to get this what should i get after i do that
POSEIDON said:
He's being a bit over-dramatic about this, but he is right. Although I have friends running 10psi daily on stock pipes and stock ECU.
I thought Zeus got an EVO?
