safe to use liquid wrench on battery cable?
seatown.P5
Contributor
'03 Midnight Blue P5
If this doesn't belong in here, please move.
The positive battery cable is stuck on my old SAAB, I think the nut and bolt are damaged from corrosion or something. Can I safely use liquid wrench or something similar to loosen it? Removing the neg cable of course.
poor a little coca cola on them on them to get the corrosion off...
but yeah, you should be ok, I don't see why using liquid wrench to loosen them up wouldnt be a problem, just make sure not to hit the + and - terminals in the process. Look at the can and see how ignitable the stuff is.
Cleaning terminals
I usually mix some baking soda with water and apply it with a used toothbrush. It doesn't take much and really disolves the corrosion. YRMV
-Scott
Coke huh? Interesting...
The battery is as dead as a door knob, so I don't think I have to worry much about shocking myself. Of course, my wife is freaking out about it.
:rolleyes:
