safe to ignore my CEL for now?
nealric
Carless :(
My p5 is at 73k miles.
I have intake/headers/exhaust which have been on for 20k miles now.
Driving home from work on the freeway my CEL came on (pissed)
Car is running fine- no noticeble difference.
The only thing I have done to it recently is change the oil + filter 1000 miles ago (but only 4 days)
Already checked the oil level and the gas cap.
Problem is that it is 15 degrees out right now and the parking lot is completely covered in snow- and there is no prospect for it warming any time soon- more snow this weekend.
Is it safe to just drive on it for another week or two or could I be seriously messing things up?
at one point I almost took the dash apart just take the bulb out of the cel.
My cel came on after 4 months of having the car and stayed on for at least 2 years.
So unless the light is flashing, I honestly believe you'll be alright for a few days.
carefull some time on some cars (i know fords truck for sure ) when u remove the light it may start beeping
yeah and aslong as the cel is not flashing its not a that big of a probleme ... its not major .... only like a evap leak or o2 fault
Our cars do not beep. Several of the early turbo guys took the light out but I highly advise against that.
What you need to do is head over to Autozone or something and have the code read. Once you have the code the severity of the problem can determine if you should be driving.
^^ X2 on above.
Hit an Advance Auto, AutoZone, mayeb even NAPA. They have the OBDII readerss, will plug it in and read the code for free. Once you know the code, then go from there. Maybe even post back here and be sure.
I personally would not advise letting it go too long w/o checking first.
The general rule of thumb is:
Orange lights - NOTICE, there's a problem. Check it out when you get a chance.
Red lights - WARNING, something serious is wrong, better pull over ASAP and addres it immediately.
or what u need is to be a mecanic and have acces to all of those scan tools :) and all the rest :)
Why don't you guys that have a CEL on get a scanner? You can get one new for around $80 bucks, reads codes and reset them if it's an O2 or evap code.
This is one of those 'it depends' situations. Without knowing the code, there's no way to know if it's 'ok' or not. Get it read, then we can give you a better idea.
Nealric,
I had the exact same thing happen to me today. I've got just over 70km and about 1000m on a new oil/filter change. Oddly my intake, header and exhaust have been on for about the same time as yours . . .
I'm going to have the CEL read at lunch today at Advanced Auto. I'll post what I find here.
So this morning, I just decided I would reset the ECU and see if it comes back on.
I drove the 10 miles to work and no CEL. However, the brake light is now on and will not come off- it came on while driving on the freeway. Maybe its a coincidence but I am beginning to think there is some sort of electrical problem with those lights.
Anybody know what the circut is like for the brake light? Is it a simple contact circuit wired directly to the dash lights or is it run through somehow with those other lights?
Raven Hawk said:
My CEL code came off as:
P0300
Random/Multiple Cylinder Misfire Detected
Any ideas on what might cause this?
How old are your plugs?
If rather new, within the last 30K if not iridium, take your ignition coils out and switch them adn reset the ecu. If the CEL comes back adn the code reads a certain cylinder misfire than switch them againa dn see if it moves. Someitmes both will go out causing a multiple cylinder misfire code. There can also be bigger more expensive issues dealing with misfires but I like to start cheap adn see fi that fixes it.
You can also search on here for that code and see what threads pop up. I know there is a thread in the 3rd Gen Protege section.
Nealric:
Check your brake fluid levels in the reservoir. When they are low the light will come on.
What CEL code are you running?
