s*** audio system...
VictorZZZ
2014 CX5 AWD
so we all know the audio system is bad but this is becoming ridiculous
the IPOD integration just stopped working. it gets stuck at "Ipod reading". changed cables, no difference. this is for a standard 160gig ipod, classic one. worked fine for many months.
anyone have a solution for this?
second problem is with bluetooth audio from my android phone. It also stops streaming to the head unit, even though they are connected to eachother and audio is enabled. I had this before and I don't remember how I fixed it, but it wasn't easy.
Anyone know a solution/reason for this?
I have heard the iPods have more issues than iPhones for some reason. Maybe further compatibility issues manifest themselves with the older Apple devices?
Does vehicle fall under this TSB?
TSB: 09-003/14
MULTI-MODEL - BLUETOOTH SYSTEM INOPERATIVE
BULLETIN NOTE
This bulletin supersedes the previous bulletin 09-003/14, issued on 1/14/2014. The DESCRIPTION, REPAIR PROCEDURE, PART(S) and WARRANTY INFORMATION have been revised.
Changes are noted below in Red beside the change bar.
APPLICABLE MODEL(S)/VINS
2014 CX-5 vehicles with VINs from JM3 KE ****** 367697 - 403269 (produced June 28, 2013 through October 11, 2013)
2013-2014 CX-9 vehicles with VINs from JM3 TB ****** 424547 - 428289 (produced June 26, 2013 through October 08, 2013)
2014 Mazda6 vehicles with VINs from JM1 GJ ****** 130589 - 151416 (produced July 01, 2013 through October 09, 2013)
DESCRIPTION
Some vehicles may experience one or more of the following Bluetooth symptoms:
When the vehicle started, the registered device would not connect with the Bluetooth system. The Bluetooth, USB or Pandora tab on the audio display would not illuminate (gray out).
The Bluetooth, USB or Pandora Tab on the audio display would illuminate, but the Bluetooth system would not operate.
When the customer presses the "Talk" button on the steering wheel, the audio display momentarily shows a message cStarting up Bluetooth Please wait" then the Bluetooth unit does not work.
NOTE:
Phone Paired - The steering wheel pickup button will only answer phone calls.
Phone Not Paired - The steering wheel pickup button will initiate Bluetooth pairing function.
