Antoine
Administrator
Mazda RX8 performance bolt-on from GReddy
by Stuart Waterman
Autoblogs SEMA embedded journalist, Eric Bryant, just cant resist a good engine display. Heres one from GReddy Performance Products that should answer the biggest criticism of Mazdas nifty RX8 - not enough power and torque.
This Turbo kit for the RX8 rotary increases horsepower by more than 29 percent, to 261 hp, and bumps the torque figure from a limp-wristed 125 ft/lbs to a beefier 176 ft/lbs, while flattening the power curve to give more mid-range grunt. Like the sign says: Add boost, torque and thrills!
Its all good, and you can install the kit in a day (or so). More after the break.
Heres what you get when you open the box:
- GReddy/Mitsubishi T618Z turbo
- front mount intercooler
- pre-programmed e-manage system, with pressure sensor, adapters and plug-in harness
- cast-iron manifold and downpipe adapter
- aluminum piping
- Airinx air intake
- a whole lot of hoses, hardware and brackets.
