180deg.Kooldino said:How much did you rotate the bearing the first time?
Guess he didn't think to try my way?? Unless you have both wheels up in the air and the steering wheel locked to either sides the bearing you're working on they won't drop out of their sockets with the endlink still connected. And putting them back in their sockets is also tricky with the end links attached.Kooldino said:Wonder why he wants you to disconnect the endlinks...hopefully he'll pop in here.
Well I'd blame his lack of wheel hop on the mounts. My friend has the AWR front engine mount on and it did a great job minimizing the hop. He has that, plus yours, so it's even stiffer.Kooldino said:I've heard that camber affects wheel hop. I know he has motor mounts (read his post - I made the rear one for him myself), and they definitely help reduce wheel hop, but it doesn't get rid of it completely.
Probably a little under -1.5 if you try really hardFlyinMSP said:What's the max negative camber that's possible in stock form? And how much more with the strut rotation mod?
Did you look at the pic on delsing's site and assume it was the driver's side? That's what I thout at first glance...that would explain the 180* change.CustomMSP said:180deg.
CustomMSP said:Probably a little under -1.5 if you try really hard
My strut bearing came from the dealer in the correct position for max camber. I could only get -1 degree out of it. So I added camber bolts and am now slightly over -2 degrees. But without camber bolts I would not expect you to see much more then -1 degree.FlyinMSP said:Thanx!Then I guess that with the mod it's possible to reach -2 degrees, right?
Mallard said:My strut bearing came from the dealer in the correct position for max camber. I could only get -1 degree out of it. So I added camber bolts and am now slightly over -2 degrees. But without camber bolts I would not expect you to see much more then -1 degree.
Yes. Although I think I could rotate them to gain caster, they are in the position for max camber. I haven't looked at them since the beginning of the summer, that's why I say 'I think.' I had never seen a thread about this mod from someone with an 03.5 so I had always wondered if they all came like that.FlyinMSP said:So your dealer had already rotated the struts?
Exactly.From what I understand from this thread and from Delsing's site (http://www.delsingmotorsport.com/mazda.htm), the strut mod allows a -1 camber (maybe slightly more), for more we must use camber bolts.
Not much.I wonder though how much camber it's possible without any mods? Seems like it can't much at all!
The -1.5 already included this mod.FlyinMSP said:Thanx!Then I guess that with the mod it's possible to reach -2 degrees, right?
Read what I'm saying man.Mallard said:Well I'd blame his lack of wheel hop on the mounts. My friend has the AWR front engine mount on and it did a great job minimizing the hop. He has that, plus yours, so it's even stiffer.
That's exactly what it is.The only way I can think camber effects wheel hop is that the amount of contact pach changes the effective spring rate and keeps everything from vibrating, but that sounds highly unlikely to me.
How did you dial in the camber?I have stock motor mounts and I'll have wheel hop with my stock tires, but I get none with my Azenis. My guess: The stiffer sidewall changes my effective spring rate and now I'm not in a range that excites the drivetrain. Oh yeah, and I have over 2 degress of negative camber.
I see your point, but like I said, before he did this he still had some hop. I may just do it to see.Mallard said:I hear what your saying, but the -1 degree in camber does not change the contact patch that much. I'd be suprised if it was even 1/4" TOTAL. You're saying that he's riding a rail so thin that --> |....| <-- that much changed his set up between night and day? That's so small that the rate of his drivetrain must be on a knife edge, and IMO he just hasn't been in the right conditions yet.
I dialed my camber in by using camber bolts in the upper hole of the upright. (not sure if that's the best way to say that). It's simple. Replace stock bolt with a cam bolt, rotate the bolt, get more camber, then fix the toe. My bolts are maxed out.
