C ccrbjr Member Jun 30, 2014 #1 Hay I have a problem with the room fuse. Every time I hook the battery cable up the room fuse blows out and I have been through a bunch of them and can't figger it out can some one help me.
P Preferio I break stuff. Contributor : 2003 Mazdaspeed Protege 1660, 2004 Winning Blue RX8, 2005 Mazda6 Jul 2, 2014 #2 It's a short to ground on that circuit. Get a wiring diagram and a multi-meter and start checking the wiring.
duffbuster243 Jul 2, 2014 #3 I had the same problem, I believe it ended up being that the rear defrost was shorting out.
P Preferio I break stuff. Contributor : 2003 Mazdaspeed Protege 1660, 2004 Winning Blue RX8, 2005 Mazda6 Jul 2, 2014 #4 duffbuster243 said: I had the same problem, I believe it ended up being that the rear defrost was shorting out. Click to expand... I remember seeing a thread where someone else (or maybe you) had that problem.
C ccrbjr Member Jul 4, 2014 #5 How can you tell if the defrost is shorting out would it be a fuse or would it be the wire and can you just disconnect it and that solve the prob Sent from my iPhone using Tapatalk
