RKE/AKE Credit card key issues
So im back to trying to figure out why my RKE/AKE stopped working on my ms6( keyless entry/ignition doenst work though i can unlock and lock with the fob).
After picking up a parts car cant get the credit card key for either car to pair with the other. Though the parts car credit card key works for keyless entry and ignition.
I'm going to get a new credit card key for programming puroposes but cant figure out if there is a difference between two different part numbers
GPYA-67-5RYC
fccid: BGBX1T458SKE11A01
TDY2-67-5RYA
Some sites say that the bottom one works for bother cx7/cx9/ms6 but others say only the first two.
Both are 3 button and should work.
Any body knows if there is any issues considering they are both the same fcc id?
Outside of a new card anyone have any suggestions to try or look at. The key did work originally when i got the car. I replaced the rear antenna and have another center antenna on the way but the fact that i cant seem to get either key to pair with the other car using forscan is making me wonder if both the key/system is kinda borked in my ms6.
