Rishie's FITMENT RECIPE
Hmmm... I don't know the answer to that question but I sure would like to know as well. From what I've been told that will work on the car pretty well but I don't have personal experience to draw from.
well, the stock wheel offset is 50, but your adding to the width of the wheel by 1 or more inches, so with 48 the centerline of the wheel is closer to the center, but the outside edge of the wheel is farther outside that stock.
does anyone know if 18's with a +45 offset on 215/40's would fit on my dx without any rubbing?? I was thinking about dropping it maybe 1-1.5 inches all around.
they will not rub if under 7.5 inches in width
Probably wrong place but this discussion eems to be visited by so many. Anyway I am looking for a lightweight 17" black rim that is 200 bones or less if possible with the correct offset. Any ideas are apreciated as this is harder than it should be to locate.
Marcus
rishie-
hyper 5zr 3piece in the 20'' size
at planetperformance.com they have a break down.
im getting the sheetmetal work done soon
and adapters, since i cant bring the car in till i get the rimz, help me please
which is the proper=5x112,114.3, or 120
which offset= +12, +25, +31, +44, +57
i might go with the 8.5's if not the 8's.
thanx for your help
Marcus
5Zigen FN01R-C 17" is 16 lbs and comes in black. prices vary but should not be over 200.
5 x 114.3
+57 with a 20", you will have to adjust the fenders to prevent rubbing
an 8.5 will not work as well as an 8. either one will require massive fender adjustment and thin ass tires. i suggest using 20s only at shows.
Iconoclast said:
rishie-
thanx for your help
Konig Holes
I know Rishie is busy, but how do I contact him to make a buy if he indeed has the lowest price. i am ready to buy if that makes a difference. I am just trying to find the lowest price.
(group) Marcus
Many times I do not have the lowest price, but I've been willing to provide information to the community that is invaluable and from the graciousness of my heart. I would appreciate it if you would take into consideration the sanctity of mind we have to offer you should you need wheels that fit without problems.
thanks, Rishie
Pm or email:
sales@autornd.com
so a +42 would push the wheels out towards the fenders more than a +50 right? i'm just trying to get a wider track then stock.
Yes, they would...
hey guys i need ur help on this....i plan on buying this rota gt3 ( gab replicas) 16x7 5x114.3 i dont know the offset but anyways i have tein lowering springs and i like how my mp5 is sitting on the stock wheels. here's the q?
will this rims fit on my p5 w/ no modification? i.ex. boring the center hole w/ dremel etc...
wut would be a good tires that would look low pro and at the same time wide when looking at the car from the rear, and not too much fender/wheel gap. well, atleast 1/2 inch gap. will the 215/45 fit rite?
oh, btw rishie can u give me a quote on a wheel package for that gt3 and the tires too...pm me w/ that tho. thx!
if the offset/width/size/etc of the rim is the same as stock and the tires are the same size as stock, your car will sit the same. gt3 will fit as long as the offset is proper
want rims, but now sure of Size & fit
got a 2002.5
i want either 17s or 18s
but i'm gonna get the TEINs springs, which are about 1.8 inch drop in the front and 1.5 or so in the rear... now.. does anyone know about this? like what size tires do i get if i get 17 or 18" rims?? i can't do with rubbing, and i dont want my tires to look like this... / / \ \ =\ help..? i need #'s!!
1st post of this thread tells you your options
got a 2002.5
