Rims Do The Trick...For Sure !
just picture it with a drop....would look almost like this (first)
Just because they don't she a listing doesn't mean they don't make the correct fitment...
Damn !!! That does look good. I am going to drop it but dont really want to give up the smooth ride. Any good springs out yet? I dont have time to look, I work 24/7.
Spool-N-Up said:
Put some wheels on the Speed6 and it draws some attention, thats for sure. Im not one that gloats at anything but people love to see nice cars and this is def. one of them. Do like I did and get your baby some new shoes. Haha
since you looked for rims, do you know if 19 or20 inch rims will fit without too much rubbing?
If you look at mine now you can see that 19's wouldnt be a problem to tuck in . There is sooo much space....if I had the money I would go on and get some 19's. 20's would be cutting it close for clearance.
Rims size has little to do with it... You could run 14" rims with HUGE tires.. or 19-20's... with nothing but a rubberband.... Just depends on what you want..
However from my research into aftermarket wheels.... because of our AWD setup... we are somewhat limited at what will fit on the rear... i'm 100% sure 19's will as I've tried a few on....
This sucks considering the size of our car... it would look good with 19 and 20's... And since we aren't a light weight rally / drag car...
Wheels look great as does your car. AutoExe makes springs and coilovers for the speed. Eibach also makes springs for the speed.
the only thing i dont like about the MS6 is that it dont have the ground effect look like the regular 6s (ie sideskirts and frontend)
