Reworked Stock turbo
Bigg Tim
MazdaSpeed 6
"I had my stock turbo reworked (by guy in New Jersey that I am not allow to name his name) to be able to flow more boost. My stock turbo was reworked to flow 575cfm which is like 39lb/hr. I went to dyno after the upgrade but I had boost controller issues. The pre upgrade dyno I made 226whp 264wtq with an MBC set around 15-16psi. The post upgrade made the same power but that was on WG only. The WG is a 15psi one so with the pressure drop through the stock core, that means I got 12-13psi at the intake.
These are just guestimates since I do not know for sure what it was running. My boost gauge read 14psi, but it doesn't read correct compared to 2 other mechanical gauges. I'm usually 1psi more then what the mechanical ones say. But for this, I say I made the same power with 1-2psi less.
The turbo is good for 20+psi before it goes out of its efficency range. It pulls harder and longer then the stocker so it definatly made a difference. I will be doing another dyno later, I need to get my EBC setup right. I also want to be able to run more boost without fuel cut so I can show the potential of the turbo."
I have not been able to get back to the dyno, but this thing does feel stronger then the stock one. I will get the pics back up later. If you want more info, you'll have to PM me or check the other board for the prices.
Nevermind, Modern Performance is where I had it done. Call them for pricing.
hey Tim, i'd like to talk to you or nick about this if you are interested. let me know.
Sorry, its hot as hell and any numbers I would get now wouldn't be an accurate comparison, but I'll try setup an appointment once my new clutch is broken in.
I'll send you a PM since "they" don't want it posted here. Or you can go to the other 6 forum and look there.
Yeah, he's usually busy but if you leave a message he will get back to you. Try to send him an email also......but talking to him is the best thing. He just did another guys turbo and he got it in, done and out within the same week. He even ported the manifold.
leaking oil turbo
Tim
If I send this guy my turbine, think he can fix the oil leak in it as well, my car is smoking two packs ALL the time :/
I treid to go last Saturday but they were having a dyno day and I couldn't get in. But it's a good thing that I couldn't because now I have a J&S and a TXS adjustable FCD that will be installed hopefully this week so I can get several different dyno's at different boost levels to show what it can do. I was only going to be able to do a 15 and 17psi run but with the FCD, I'll try to go up to 20psi as long as there is enough fuel and I don't detonate.......but that's what the J&S will protect me from.
If I don't get it this Saturday, then it will definatly be the next....it all depends on when I get the parts. I have made a "pending" appointment at the shop already for both day's, just in case.(thumb)
Sorry, it aint gonna happen now. I've been getting ignored by the person I bought the FCD from and don't have it yet so I don't want to waste the money to dyno without it installed. Whenever I get the damn thing, I will get it done, but not tomorrow. Now that I have it in my mind to get that FCD, I want to be able to do multiple boost pulls so there's no point going without it. I do have the J&S, but that isn't really needed until I start upping the boost and risk detonating.
men who you bought the FCD from?
I bought it from a guy on the forum and wasn't responding to my PM's, 2 weeks worth, but now he finally has and it is supposed to be in the mail. I have a 9am appointment for this coming Saturday AGAIN, so hopefully I'll have it before then so I can install it. If I don't get it by this Saturday, I will postpone the dyno again until I get it, but my fingers are crossed.
I know people want dyno numbers and I want to get numbers out there and also for Nick so I am definatly going to dyno once I get the FCD!!!
if you think your getting scammed let the mod team know....we don't want this crap to happen on here.
