- 2002 BJFW, 2007 BK3P, 1979 SA22C, 2005 BK3P
Do we know the reason behind it? I can't foresee the boost from the turbo being the issue. Most of the time it's from not running enough oil in the car.
We need to get this batch of turbos out, installed, so we can post other reviews because this isn't too appealing to the Mazda community, but sounds like the turbo held up like it should have.
i agree. i am beginning to wonder, after looking back at some of ms3guy22's tuning nightmare photos where all the smoke and blue smoke was occuring, whether or not that was actually the engine or the turbo pissing/consuming oil now.
I find this totally weird. How can he spin a rod? All he did was a turbo. Coincidence is a b****. Just a very random issue here. Please let us know EXACTLY what happens here.
sometimes you have to look at an automotive problem not in the sense of immediate cause and effect. you beat on a clutch for example and then baby it for a few months but it still goes out down the road, sooner than you would have liked. the damage could have already been done here by something else. the turbo can be eliminated from the cause because upon inspection the turbo was in perfect order - no shaft play, no shavings, spooled fine. if something let loose in the turbo and caused a rod bearing to spin (which is, for the record, a near mechanical impossibility), the evidence would be in the turbo. lets not forget he pretty much never boosted the engine on this turbo. he drove the car around and spooled enough to touch 5psi if that, and only once. there are people who get away with 30psi accidents on GT30s whose motors are still chugging along just fine.
i don't think in terms of coincidences. i think that all the punishment this engine took from the work and parts that came earlier turned the engine into a time bomb. bearings are in a sense, a wear item. if you beat the heck out of the engine enough they are going to wear out and do what happened here.
ur a fool!
really? is he? do tell why exactly you think that. we have speed6s and speed3s blowing motors and snapping rods on STOCK cars with ZERO modifications. we have DISI engines with crankwalk under 20,000 miles. we have mazdaspeed vehicles with more TSBs and service bulletins in two years than the regular 3 or 6 has had in five years combined and you think its foolish to consider there just might be some design issues with these cars?
all this going on while there are those who sit on the sidelines and praise the press release proclaimed strength of these engines and the genius behind the DI design. remarkable.
