Review: Raceroots (Progress) RSB
nynhex
1st and 2nd Gen MS3s have pretty good suspension from the factory, but let's face it. There's always room for improvement, especially in a FWD car. That being said, I was looking for the biggest bang for my buck and I'm pretty sure I've found it with the Progress Rear Sway Bar exclusively from RaceRoots.
Price: $185 USD
Manufacturer:
Progress
Specs:
- Bar Size: 32mm
- Bar type: Tubular Bar
- 2 Way adjustable
- Polyurethane bushings
- Reinforced mounting plate!
STOCK: 25mm Solid non-adj 862.12 lbs/in
2 settings of stiffness:
(soft) 56% stiffer than the stock sway bar with a rate of 1342.89 lbs/in
(firm) 79% stiffer than the stock sway bar with a rate of 1542.27 lbs/in
First impression:
Opening the box I see this monster sway bar and I start to smile. I'm used to 25-27mm sway bars on some of my other vehicles, but this thing is gigantic at 32mm. The machining is very precise and the welds very clean, a trademark of Progress products.
The powdercoat gray is a nice touch and doesn't stick out on the undercarriage. I was afraid of it being too obvious since I drive a Black Mica but it blends in pretty well.
I compared the stock bar to the Progress and let me just say it was like a toothpick next to a crowbar. You can feel the difference just by holding the two. I'm not going to lie, but I thought the production quality of the Progress was superior to that of stock.
Install:
Now, I'm fortunate enough to have lift access and air tools so my install was a bit quicker. The instructions suggest you remove the rear tires. Don't bother, trust me it's not needed. I undid the endlinks thent he bushing brackets and the old RSB was off in 5 minutes.
Progress includes grease for the bushings (MAKE SURE TO USE IT!!). I put the bushings on, then the brackets and bolted in without torquing so I could get the endlinks back on. I started off with the soft setting (outer hole) to get a feel for things, but after my test drive I switched to the stiff setting (inner hole). Make sure that you torque to spec on everything and USE LOCTITE on the endlinks. They tend to come lose after a while. After everything was torqued down, it was time for a drive.
Drive/Testing:
I first started off with the soft setting just to get a baseline. I took a few corners at 30-40mph with little body roll and a slight reduction in understeer. I went about 5 miles through a closed area and really got on it, it was noticeable but not to my liking.
So I put it back up on the rack and went to the stiff setting. I took it out on the streets and my face lit up like a Cheshire cat! My first turn was a 90 degree at about 45mph I was white knuckling it because I didn't know if I was going to throw my car into a median and crash but the rear-end of the car whipped around and I literally got a little sideways. This was incredible.
Next I took some less sharp, albeit longer turns at high speed. Hitting some freeway ramps at 70mph+ that had some hard banking, the car kept flat and the rear end of the car wanted to swing around.
I then went to our private parking lot and mimicked an Auto-X run. I was whipping around turns effortless and the car just felt "flat" body roll was about 80% gone, understeer tremendously reduced, and oversteer introduced.
Needless to say the stiff setting really did the trick and changed the entire dynamics of the car.
Summary:
I've been shopping between the Progress, Autoexe, and Hotchkis bars. Although I've used Hotchkis on a couple of my cars, I could not justify the bloated price point. Progress offers a solid product at a fraction of the price of the competitors.
I'm one of the first 2010 MS3s to install the RSB so it should also be known that I have zero suspension mods on my car besides the RSB.
Between quality, fitment, and price I highly recommend this mod to any 1st or 2nd gen MS3 driver.
I guarantee you'll love it!!!
-NyNHeX
Very nice write up! I've been wanting to upgrade my suspension on my Mz3 but haven't really researched my options yet. This does seem like a promising one though, I will probably be ordering and installing my "list-o-mods" in march and this will likely be on it!
any pics and such? :)
This is about as good as I could do underneath the lift with my iPhone.
Sorry..
Give us an update periodically on how its holding up over time. Any loss of stiffness, durability, etc.
so this RSB not made specifically for 2nd gen right? you just bought the 1st gen one and installed it right?
Correct. As far as I know there is not any suspension parts made specifically for the 2nd gen yet. This one works great in mine.
