Reverse Rattle?
scott42
Contributor
Blue MP3 #1169; '06 Subaru B9 Tribeca
Does anyone have any clue what it could mean... :confused:
Basically when I'm in reverse and engaging the gear, I get a wierd rattle sound from up front (trans area) :mad: Sounds almost like a loose heat shield, though not as loud or pronounced; but its only in reverse, so I don't think that's it...I'll be heading to the dealer sometime soon for the new bushings and figure I'd have to ask about the rattle as well. I'd like to have a clue so I can give them an idea as to what they are looking for.
Thanks:cool:
if it's MTX, do you have the stock shifter or a short shifter installed? if it's a short shifter, make sure the base of it isn't hitting against the heat shield ..
nope, all stock, no changes whatsoever to the tranny, or anything else for that matter.
CAI and grounding kit is the only extra-cerricular (sp?) under the hood :D
