Reverse Indiglo's installed!!!
1999 Mazda Protege "Sport20" FS-ZE swap
Thanks to rice a roni for telling me about these. They are much better than the standard indiglo's. The tach needle for me was very hard to slide in, but I eventually got it. Here's some pics:
They should fit the same. The numbers and everything are still in MPH. Holes line up and everything. Only difference is whoever placed the tach on the left is a dumbass because it's supposed to be on the right.
Those are sweet. I have wanted them since I first saw them, looks to be a lot easier then changing the lighting. But my only problem is I have the sport auto and would have to cut out an area for the gear indicators to show through. Haven't been able to think of a way to make a template without removing the factory gauges. I suppose I could try to measure it and mark it off, but my fear is that the measurements would be off and I would somehow ruin my new gauges.
damn you (j/k). so you were able to slip them over. I have the same gauges and had trouble with it. I just ended up cutting them cause I was getting pissed.
