I noticed when changing gears manually on my Signature with turbo that engine power was reduced at a tad under 6000 rpm i.e. just under red line. I imagine this is a safety feature designed to protect the engine from over reving. Correct?
I came across this issue today. In sport manual mode and the trans changed up around 5000 rpm.
It redlined around 6,300 so I don't understand why it does this? Surely these engines are not that fragile, are they?
Yes it shifted up around 5200rpms in manual mode without me touching the steering wheel paddles.Can you explain what you mean when you say "the trans changed up"? Do you mean it shifted into the next gear?
Yes it was and in Manual mode.Was that with Sport mode on?
Perhaps this will help clarify. There are actually three modes:
Sport mode - This is activated using the rocker switch to the left of the shift lever. In Sport mode, the transmission will upshift later and hold a lower gear. The throttle will become more sensitive. The transmission will still shift automatically. The downside is more engine noise and lower fuel economy.
Manual mode - This is activated by moving the shift lever to the left while in D. You can then manually select a gear using either the shift lever or paddle shifters. Invalid gear requests will be ignored. The transmission will downshift automatically as you come to a stop. The transmission will also downshift automatically if you press the accelerator past the detent position. Otherwise, the engine will hold the selected gear and will not upshift automatically, but the engine's rev limiter will keep it from going past redline by closing the throttle.
Manual mode (temporary) - This is selected in Sport or "normal" by pulling a paddle shifter to temporarily choose a lower gear such as when engine braking is desired. "M" appears on the instrument cluster beside the shift indicator just as it does in manual mode, but unless the shift lever is in the manual mode, the vehicle will override the chose gear.
Manual and manual (temporary) mode can used in either "normal" or "sport" model.
This can get really confusing for drivers who don't fully understand each mode. My 2019 RDX took a while to figure out. It had a pushbutton shifter that had PRND and S (sequential mode) positions, paddle shifters, and four drive modes (Snow, Comfort, Sport, and Sport+) resulting in many combinations of shift behavior. Sequential ("manual") mode only became manual when you pulled a paddle shifter and would still upshift automatically near redline unlike the CX-5. Otherwise, S mode was more like Mazda's "sport" mode, but only for the transmission - the rest of the car (dampers, steering, throttle, sound) didn't change. Those parameters only changed when you chose a different drive mode (i.e. Comfort or Sport+).
Very helpful. It seems that having it in Sport mode overrides the Manual mode, which is what I suspected.
@Akera, if you put it in Manual mode with the Sport mode off, you should be able to "bang the rev limiter" as much as you want.
In my experience with the CX-9 (and as a few CX-5 owners have reported in the past), Sport mode doesn't change throttle sensitivity. I could be wrong, but I've played with it a lot and as far as I can tell, it doesn't.
Sport mode and manual mode are mutually inclusive.
When the shift lever is the M (manual) position and a gear is manually selected using the shift lever or paddle shifters, the engine will "bang the rev limiter" whether or not sport mode is on.
Akera says he had the car shifter in Manual mode with Sport mode on, and he was not able to redline the car. So Akera was mistaken and the car was not in Manual mode, or Sport mode overrides Manual mode and automatically shifts the engine, or there is something else going on.
It's entirely possible that the throttle sensitivity changes, but in my (admittedly limited) experience, if it does change, it's imperceptible. Thanks for reaching out to your rep, hopefully he/she's got some answers.
The Skyactiv turbo is built for torque and tuned to short shift to get to lower rpms for max MPGs. Just run it hard and don't worry about breaking it. Mazda capped it due to preserving mpgs plus there's not much power up there.
The Skyactiv gas engine in the Miata redlines to 7500 RPMs mainly from lighter pistons and connecting rods plus better spring valves. Wider throttle body to gulp more air. Plus of course it has a sportier tune.
Hi, I had the car in sport mode and the shift lever moved across for manual mode.I believe @Akera had sport mode on and manually selected a gear using the paddles shifters without the shift lever being in the M position or had pressed the accelerator past WOT (until it clicks). If so, this would explain why the transmission upshifted before redline even when a gear was manually selected.![]()
